after about 10 mins you want to check it by trying to pry it with a large flat head.. if its still tight then throw it for another 5 min.... once you have one side pried out all you'll need to do is pull slowly to remove the outside lens... i really don't think you can buy the lens separately.. the lens it removable though as i took a light apart... i actually might have one clear lens sitting around...
