I believe the overflow tube exits in front of the right side rear wheel so the problem would show up exactly as you've described. If the coolant tank ruptures there's a good chance you'll find coolant in the trunk compartment as well as on the ground. I've replaced my cap twice with no other leaks present. Try the cheap stuff first.
