Adam..................
no the bumper does not have to be removed. I think the main piece that needs to be fabricated is one the goes across the top of the GHL exhaust with holes to mount the two bolts. Then you need a mount that will tie it together with the bracket (or make a new one) onto the transmission/frame. You will see this if you look under the car. I couldn't have done a better job than this guy but I don't have access to a machinist and welder that i know.
