Old 04-21-2010, 12:41 AM   #2
sickbananas
interior paint
Hi,
you get an aerosol plastic primer which will work perfectly on the plastic parts. In my experience I have sanded the parts with 600 grid sand paper, sprayed the primer and then you can use either an aerosol gloss black or 2k paint on top of the primer.
after sanding, wash the parts in water with some soap using a scotchbrite. Then dry and apply plastic primer. Only apply one coat of plastic primer-thin.
do not use anything solvent based before painting.
Rob.
sickbananas is offline   Reply With Quote
