skip the tubes, along the lines that if they're not leaking - leave them alone. If you change them (not necessary - just swapping the 'o'rings will do), you'll need to pull the plugs in a few hundred miles to make sure you got them seated properly and that they're not leaking, which is another reason to leave them alone if they're OK.
Cheers!
