Thread: window problem
Old 04-14-2010, 04:55 PM   #1
greybox
window problem
I changed my battery and my drivers window worked for a couple of times then stopped working. I could hear the motor "tick" when I touched the button but the window did not go up or down. I took the whole thing apart and found that the motor was fine but the winding mechanism was very stiff. Took it all apart fixed and now works fine....except for one thing. It's backwards. I read somewhere that if you remove your battery and reconnect you must turn your key on for 60 seconds then in the off position for 10 seconds. That didn't work. Any ideas?
greybox is offline   Reply With Quote
