Originally Posted by chitowndad
I got these gembella springs a while back that lower the Boxster a full inch (from someone on this site) and my question is can I simply drop them in place and realign the car or do I need to add drop links or something else to prevent excessive tire wear if I install the springs?
Thanks,
-Steve
A knowledgeable alignment person should have no problem dialing in the right amount of camber without resorting to additional camber plates. However, when you refer to "simply" dropping them in, there's nothing simple about it. Its quite an undertaking, and it requires an experienced person to do it right. I'm sure that you know that.
