Old 04-13-2010, 05:26 PM   #34
Steve Tinker
Steve Tinker's Avatar
dti,
You don't have much history of the car (Why did your Aunt take it off the road? Was it broken? Just lack of use? Did the inter-mix of fluids happen over the years of sitting). As you said, your plugs look good, so maybe the engine is just suffering from the standing idle and 120,000 miles on the clock.
If your serious about getting the engine up and running relatively cheaply (ie, not removing the engine and heads), have you considered spending a few hundred dollars on a new cooler, replace the oil and filter and flush out the cooling system? Sunset or Pelican Parts will sell you a cooler for a couple of hundred $$ and the oil / filter / distilled water another $100 or so.
Then run the car gently for a few miles and see if there is any inter-mixing of fluids - if there is, then you know where you stand, with a big decision as to buy another engine or rebuild what you have got. If no inter-mixing, thats a big win and you can reassess what you want to do to get the car up to scratch.
After all, unlike most of us here, you havn't invested thousands of $$$ in the car so what have you got to lose??....
2001 MV Agusta F4.
