Thread: Radar Detectors
Old 06-25-2005, 07:38 AM   #31
porscheguy05
The solo and 8500 are definetely not the same, and escort will tell you the same. They do not have near the same reception range. There have also been several independent test conducted that show the same. Checkout this website:
http://www.radarbusters.com/support/product-tests/4.asp
Originally Posted by JackG
Case shape and material, antenna shape, and all kinds of weird things such as mounting bracket location can play a role in performace. If the Solo and 8500 are indeed similar internally, they can still perform differently in the real world due to the above factors, as well as the added POP circuitry.
In any case, the "filtering" of the 8500 seems to not give me a problem. Even with it's filtering out of falses (and maybe some real signals?), it still, in my real world experiance and some tests, beat the V1 by a significant margin in the Ka band.
Since that's the band used in my area, not laser, the 8500 is the unit for me to have. The V1 simply lags by seconds and hundreds of feet. That's not what I want protecting me.
Of course, if there is laser being used from moving cars from the rear in your area, go for the V1. Even when it fails, you can get that tossed, because that use of laser should not stand up in court. Fortunately, it's a non-issue for me.
Jack
porscheguy05 is offline   Reply With Quote
