Thread: Caliper Bolt
Old 04-12-2010, 05:56 AM   #6
ppbon
ppbon's Avatar
Originally Posted by landrovered
I have always used blue loctite on caliper bolts, I had one fall out on me once, won't allow that to happen again. I would not personally use anti sieze on a caliper bolt but that is just me perhaps.
Your caliper bolt was loose because it was not torqued properly.
Most likely because the threads were dry!
A properly torqued bolt will stretch a bit giving the threads more area for friction, which is what holds it in place.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
