They were partially right. The connector is located behind the drivers seat up high just behind the left side of your head. It is there because the hardtop with a defroster was an option on your car. All you have to do is look at a wiring schematic or test them with a volt meter to determine which wires to hookup to the seforster connectors. You would need about 6 ft. of wire and I think four female connectors. I have not done it myself either because like you if it is crappy out it does not see pavement.
Originally Posted by Porschekid
^ Mine has been installed and I must agree. But I didn't have the defroster installed because they said it needed a wiring harness to hook up to the hardtop connector and I would have to take it to the Porsche dealer or some ****************. I'm not too worried because I only drive the car when it is nice out anyway.
