Originally Posted by S3adrag0n
Ok, just drove home, and then opened my trunk while engine still on, and took a listen. Absolutely no hissing noise from the oil cap area that I could detect. My oil cap is on tight. I did hear a little gurgling noise from the coolant tank though.
With the oil cap off or on? Mine is sucking air only with cap off; has no CEL or smoke and drives fine. I am a bit confused myself. I hear should not be sucking air and I also hear sucking air is OK with cap off.
As my post stated, "my oil cap is on tight."
