The fuel pressure spec is not 3.3-3.8 Bar.
On the early cars, before the introduction of the returnless fuel systems, there are two measurements a static measurement with no engine vacuum (engine not running, fuel pump activated) that is 3.8 +/- 0.2 Bar and the second measurement with the engine idling (vacuum to the FPR) is 3.3 Bar +/- 0.2 Bar. These measurements test both the pump and the regulator.
-Todd
Originally Posted by paulv
The manual info on Cannell (although it's dated) shows 3.3-3.8 bar (+/- 0.2 bar) for fuel pressure at the rail and fuel flow should be around 850 cubic cm in 30 secs.
Also, the fuel rail caps are not reusable and need to be replaced with new ones.
Regards,
paul...
