Old 04-09-2010, 05:45 AM   #5
mikefocke
You get codes until you fix the problem
and any other problems the original problem caused.
So assuming the AOS was the problem, did the AOS replacement guy also clean the intake tubes and the throttle body? If he did, could have left an air leak. If he didn't, could be residual oil from the AOS failure so do the intake and throttle body cleaning. Link
