Thread: Fuel pressure
Old 04-09-2010, 04:02 AM   #2
paulv
Yes and yes. And you do not need to replace the cap if you can find the small seal that goes inside it.................
Do you mean that I would need to "catch" the seal from dropping if I took off rail cap off? This is good to know even though I'm not planning on checking my fuel pressure/volume.
To me, it's a waste of time buying a fuel pressure gauge that's not accurate enough to do an injector balance test and only use it to check press/vol. Gauges I can afford are things like Actron which are only +/- 2psi mid-scale (I called the company), and I'm sure you have something that's +/- 1psi full-scale (and made in US).
Regards,
paul...
paulv is offline   Reply With Quote
