Old 04-08-2010, 10:48 AM   #5
ARModen
Top of the Center console. The boxster is a pretty smart car. I assume you've hit the "auto" button and dialed the temperature setting all the way down to "low?" The compressor should come on in 30 seconds or so if you do that. If the temperature it senses in the cabin is less than the temperature that's set on the HVAC controller I don't think the compressor will come on, even if you hit the little snowflake.
ARModen is offline   Reply With Quote
