Old 04-07-2010, 08:00 AM   #10
David Wildrick
Originally Posted by RandallNeighbour
Jack the car up and put it on jack stands in the back. Get on your back and get under the car, and bring a hammer with you.
The metal heat shields on the cats make the exact sound you all are describing.
Hit the living crap out of the loose heat shield to bend it a little and tighten it up. This will feel really good if you are as pissed off as I was with that rattle buzz noises at low speeds in low gears in alley ways or by fencing.
Then get the car back out on the road near a fence and you won't hear it any longer. You will feel the satisfaction of knowing you beat your Porsche with a hammer and that's exactly what it needed and what your mechanic would have done, but charged you for it.
I checked out what I thought was a crack in the exhaust system last night and took a photo of it. But after probing the "crack" with a screwdriver and high intensity light, I realized it was just a gap between where the bracket for the cat converter is welded to the converter and the endcap of the converter. This gap is much deeper on the right side than what is seen on the left side of the car.
In the attached pic, the bogus "crack" is denoted by arrow #1.
Randall,
Does my arrow #2 point to the metal heat shield you refer to? Or is it even visible in this photo? Thanks.
David Wildrick is offline   Reply With Quote
