Any follow up?
Hi Cesar,
"-Engine needs to be at normal operating temperatures to make clunking noise.
-Noise sounds like it coming from the rear drivers side wheel area.
-Noise only happens when car is in gear, accelerating or decelerating within gear. When clutch is engage, noise stops.
-Noise does not happen if car is at a stoplight, stopped, or freeway speeds. It only happens at street speeds.
-Noise frequency matches the speed of the car, but like mentioned above, goes away at freeway speeds.
-Noise happens regardless of surface or if driving straight/turning."
This sounds exactly like what I have with my 2000 Boxster. Have you found out what's wrong? I guess it's a good sign that it's over a year and nothing bad happened to your car.
Ken
