Old 04-05-2010, 01:20 PM   #2
JFP in PA
Probably not. If your regulator is bad, you can tell by testing the battery voltage with and without the car running with a simple volt meter; or if you have access to a load tester, perform and engine running load test, which should cause the regulator to respond with about 15.5V or so if it is OK..........
