Good tip. BTW-unless you are racing, you likely don't need that 15-50 even in summer. It won't hurt mind you but you will lose MPG and actually generate more engine heat.
Originally Posted by deliriousga
Like Adam said, stone cold is best time to check when it's all down in the pan. If you use a higher weight oil it takes much longer than a gas stop to drain back down to the pan.
When we changed to 15W50 and it shows 2 bars low after a fill-up with cleaning the windows (about 10 minutes). Freaked my wife out because she didn't know I had changed the oil weight. Flip the key when it's cold and it's all bars on the digital guage and full on the stick.
