There are a few plastic trim pieces in side the rear trunk by each light holding the carpet in place. Take those out and then you can gain access to the hardware holding the tail light in place. Pretty easy job. Make sure you save the gasket off the old light for re-use.
Since you have not posted a picture of the damaged light, if it is badly damaged, you may have to order another gasket...
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
