Originally Posted by Steve Tinker
Eight,
If the squeak is on the L/H side I doubt its the AOS as that's on thr R/H side.
If you uncouple the belt with cold engine, run the engine for a few seconds without the accessories being turned and see if the noise dissappears.
Dont run it too long though as the coolant pump is now stopped......
I'm going to carefully disassemble it this morning and attempt to locate it, I'm tempted to put a bit more pertosin in as I have checked the accessories twice already. It seldom works long but perhaps some shaft lubrication will knock it out.
EDIT HELP:
It's none of that stuff, can anyone tell me if the A/O separator is capable of making a noise?
