Old 03-31-2010, 10:01 PM   #1
carguy
Do the front engine mount and see if it helps. It's a cheap part (it's a 987 part for all Boxsters now) and procedure should only be 2 hours labour. It will fix your 3100 vibration, give more immediate throttle response, and should improve shifting - if shifting still needs some work, at least you've done the mount and taken that out of the equation.
2001 Boxster S, Seal Grey
1998 M3, Estoril Blue
carguy is offline   Reply With Quote
