I found the micro switch and it was engaged. I manually released the button and the top (motor) worked. The question is, the button was engaged as it is supposed to be, but the motor won't work until I released the button on the switch. Obviously, you can't be expected to remove the panel and release the switch manually every time you want the top up, so how is it supposed to work? Is there a reverse relay? Also, I would point out that the dash light does not go out even when the top is fully down. This is a new car to me so I am just trying to make the top work properly. I suppose I can just disable the micro switch. I had to bend the contact anyway.
Thanks. I am getting there, slowly but surely.
