It sounds like the brake feel you're looking for isn't desireable and the car is working like it should. Your brakes were "touchy" before because you just put on new pads and now they are broken in so the touchiness is gone. You don't want the brakes to be too grabby initially; some people equate grabby brakes with good brakes. The system automatically compensates for pad wear and keeps the pads right next to the rotors all the time. The brake pedal should be firm once some decent force is applied and if it is bleeding the brakes will not change anything. If it is not then I would go ahead and bleed the system again.
