Old 03-24-2010, 11:35 AM   #1
bermuditis
Send a message via Yahoo to bermuditis
Originally Posted by Viper5
You're in for one hell of a time. It has to be done from underneath the car and it's pretty much impossible. Not sure how else to say it. Why do you need to remove it? I thought I needed to remove mine because it had a leak, but I was able to buy some JB Waterweld and it worked like a charm over the hole which I could feel underneath.
Great advice. After changing water pump, cap and thermo, I still had a leak. Sure enough streaming out the bottom of the tank. Just tried the ww, hope it works. Thanks for posting that. Will use till I can order a tank.
http://www.fileden.com/files/2007/2/.../Boxster03.JPG
2000 Boxster 2.7 98,000 miles.
bermuditis is offline   Reply With Quote
