Old 03-23-2010, 04:45 AM   #12
backman_z
Originally Posted by blue2000s
Typical narrow band oxygen sensors found in most cars are only accurate in reading the oxygen content in an exhaust stream (and therefore projecting the air/fuel ratio) near the stoichiometric ratio. This is only useful when the car is running at low loads (cruising) when you want the engine to be running near this ratio. They aren't accurate at reading the air/fuel ratio when the car is at high load (accelerating) or idle. Therefore, they're not very useful for tuning an engine.
The wide band oxygen sensor has a different construction that allows it to be accurate for a much wider range of air/fuel ratios. With this sensor, you can measure and tune an engine for optimal operation under all driving conditions.
Jaay, congradulations on the baby. Kids are great. I have 4 myself.
Anyway, I too am new to Boxsters and a lot of this tecnical jargon. Though I have done a lot of my own basic car maintenence and repairs, I have never done any performance mods to any of my cars.
Let me see if I can get this streight:
- This gets installed on the exhaust
- I presume it somehow gets hooked into the cars computer?
- It can help the cars computer to improve air/fuel ratios
- It can improve performance and I would also presume efficiency
Anything else missing?
Frans
backman_z is offline   Reply With Quote
