Thread: Brake pads
Old 03-22-2010, 08:51 PM   #5
Lightning
Lightning's Avatar
The pad sensor is just a loop of wire that the ECU puts a small amount of current through. When you've worn enough of the pad, you then wear through the pad sensor, breaking the connection, which the ECU sees as a low pad.
If you're going to use track-oriented pads without wear sensor holes in them, save your old broken wear sensors. All you have to do is cut the wires on the old pad sensor a few inches below the connector (at the strut), twist them together, and either solder or crimp splice them together to re-establish the connectivity and get the light to turn off. Remember you will then need to use the two wear sensors in your head to avoid rotor damage...
Lightning Motorsports
http://www.LightningMotorsports.US
http://www.youtube.com/LightningMotrsprtsUS
Lightning is offline   Reply With Quote
