Originally Posted by yimmy149
Aren't 99's mechanical throttle instead of eGas? If that's the case, then I'd look into replacing the idle air control valve, it's probably sticking when cold.
-james
That could also be the culprit possibly, but usually if it's the idle control valve it would die when coming to a stop. He didn't mention it dying at idle, but it would still be a good idea to check it out.
