Old 03-20-2010, 11:35 AM   #1
Cloudsurfer
I have retrofitted 996 Turbo full power, memory seats in a 986 Boxster, but the 997 seats are different as far as I know. Not sure how, but I do not think they are the same. On the 996 seats, power feeds into the memory module (even the 30A main feed), and from there goes to the motors and actuators. If you don't have the memory module, expect to do a LOT of wiring. There are two pins on the module, which require power from separate fuses (at least that's how the factory wires them, so that's how I did it) at 15A each I believe, in addition to the 30A fuse for the seat motors. This will empower the seat controls to work with the seat motors and all. Unless you add a TON more wiring to the memory door sill, and sideview mirror motors, reverse signal, and a few others, you won't have memory functionality, but the controls on the seat will work.
I would search out the wiring schematics and go from there.
Boxster S
