			Sounds more like a battery failure than a starter malfunction.....
If you can access the front frunk & you have a multi-meter, check the battery voltage across the terminals - it should read ~12.5 volts (without engine running).
If less than 12.0 volts, charge battery for at least 4 hours.
If battery is more than 4 years old, replace - the hassle is not worth trying to resurrect it.
2001 MV Agusta F4.
