Originally Posted by schoir
There is supposed to be some slight suction (and an accompanying hissing noise) there. If there is extreme suction (this is starting to sound funny  ) then that is an indication that your AOS is failing. In that case, it will be very difficult to pull the oil cap off the tube.
Regards, Maurice.
And that could also indicate worn rings are causing blow-by.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
