Old 03-15-2010, 06:33 AM   #1
Paul Whyte
Originally Posted by Steve Tinker
You have to remove the appropriate wheel which allows you to see the (~20mm dia) drainage hole. If you are lucky, you will see the L shaped rubber piece lying in the appature. I had to find mine with the aid of a torch and a bent wire. The rubber drain will push strait back into position.
Thanks for the info, I shall give it a go.
Paul Whyte is offline   Reply With Quote
