If your car feels too safe and insulated, here is a prescription to cure it:
1) Get some sticky tires on light rims
2) Increase sway bar sizes. Might as well eliminate the understeer by maxing-out the front camber.
3) Put some grabby/noisey brake pads in.
4) Increase spring stiffness and shock damping (oh hell, might as well buy coilovers).
5) Replace the dual-mass flywheel with a lightweight single-mass unit. Might as well install a grabby clutch while you're in there.
6) Replace the exhaust with something louder. Try not to concern yourself with whether or not you are adding or losing horsepower.
7) Replace the seats with racing/sport seats. The harder to get out of the better.
8) Do something unreasonable to make the car lighter (Remove some of the carpeting/insulation? Toss the A/C?).
Whether it's a 986 or 987, your car will gain back a lot of the mechanical feedback the engineers worked so hard to insulate you from. Now it is not everybody's Porsche, it is YOUR (meaning, my) Porsche. Will it be less civilized? You bet, but when you get it out on a canyon road (or on the track) it will be well worth it!
p.s. Make sure to turn the Stabilty Control OFF!
