Originally Posted by cheetah
Here is my question: Are these DME's different hardware or just different programming (maybe with different pins connected)?
If it is only software, can our 7.2 computers be flashed to 7.8?
Also, has anyone on here done this particular swap?
Thanks in advance
Yes, different hardware and programming (you will need 7.8 986 DME flashed to teh cayman's engine system).
It's just not software like I said.
yes I have and so have a few other people, but not many... and the real info is hard to pry from some people.
like the above posters said, you will need to re-pin quite a few pins on your DME/wiring harness plus add the variocam plus controllers... and probably lengthen two others... Im not familiar with the small items on a cayman engine, my experience is just with the 3.6 from a 996.
