Old 03-11-2010, 03:34 PM   #1
Steve Tinker
Steve Tinker's Avatar
You have to remove the appropriate wheel which allows you to see the (~20mm dia) drainage hole. If you are lucky, you will see the L shaped rubber piece lying in the appature. I had to find mine with the aid of a torch and a bent wire. The rubber drain will push strait back into position.
2001 MV Agusta F4.
