Old 03-09-2010, 06:11 PM   #11
MN 986
MN 986's Avatar
Originally Posted by yimmy149
Other things to consider:
At 60k your front engine mount is shot unless it's already been replaced. The clunking you hear could be your engine moving.
It's worth checking that your transmission linkage is still connected. Does the car feel like it's going into gear as you move the shifter?
+1 on checking the front engine mount. I have a 2002 986 with similar miles, and I just started noticing a very slight noise under these conditions. I have read many posts on a few different forums, and I am convinced it is the front engine mount.
It is worth checking since it is a lot cheaper than pulling the transmission.
Good luck!
MN 986 is offline   Reply With Quote
