Old 03-09-2010, 04:12 PM   #1
Mike_Yi
Something else that is very important is to prime the engine. It's been sitting for months. Where do you think the oil is right now? On the rings? Nope. It's all in the sump.
So what you do is disconnect the coil(s) and crank it until you get a normal oil pressure reading. Unfortunately, in this car there isn't an oil pressure gauge. So you'll just have to crank it for a bit. Anything is better than just firing it up. In my Firehawk, it generally takes about 10-15 seconds of cranking to get a normal oil pressure. Since you don't have a gauge, and this motor is not a GM v-8, I'd crank it for 20-30 seconds to be sure. Then, reconnect the coil(s) and fire her up.
By disconnecting the coil, you will be preventing combustion. This will prevent putting a lot of pressure against the piston while there is no oil in the engine.
Of course, the best way to prime the engine is with a primer. On GM V-8s, you can remove the distributor (which is driven by a gear off the oil pump) and use a special tool on a drill which will spin the oil pump. I don't know if there is a way to do that on the Boxster.
Mike_Yi is offline   Reply With Quote
