Thread: rear diffuser
Old 03-08-2010, 07:42 PM   #17
23109VC
assuming you buy these painted..and assuming you do NOT remove the bumper and do it with the car on the ground.... and you have "average" ability..but ARE capable of doing the job - how long shoudl it take to line these up and bolt them on?
so let me see if I have this correct - the bumper has two holes predrilled...and those holes correspond to mounting points that the diffusers use? then you simply add in the third one? sounds kind of easy..
do the diffusers have bolts embedded in them or predrilled holes...so you haveto lineup the holes on the diffuser with the hoels on teh bumper? then drill one more hole in the bumper by the muffler / tips ?
overall - it must be pretty straightforward to see how they line up - or would it be very easy to put one on "crooked" and then have it look "wrong"....
you could probably line it up and hold it in place with painters tape or some other cheap/quick tape type item..then step back and eyeball it to see how straight they look...then drill it in once you iknow it's all lined up..
_____________________________
Cars:
2007 MDX - Wife's mommy mobile
2006 RL - My daily driver
2000 Boxster - Ocean Blue Base 5spd on Black Full leather. 18" wheels and M030.
Boxster mods I've added: Rear speaker kit, Painted Calipers, Painted Bumperettes, Painted Center Console, 987 Shifter Assembly, 3 Spoke Steering Wheel, Clear side markers, 03+ rear lights, de-snorkeled.
23109VC is offline   Reply With Quote
