Old 03-08-2010, 12:18 PM   #10
eightsandaces
Just wanted all to know the headers are in, I used one timesert per side and both snugged up tight. Unless there is more exhaust pressure in gear I'm confident they are leak free. I crawled under to check and blipped the throttle a couple times. Everything seems tight and beautiful sounding, actually far mellower than I expected which I'm glad about.
The plastic shroud is close to the headers, I'm tempted to leave it off but I'm thinking about buying more heat shield, which I used on the PS line and coolant lines on the other side. I thought I'd make a barrier between the headers and cover, any thoughts?
Thanks to all, BTW timeserts appear easy in the video because the dude is on a bench, when you're on your back and deploying speedbor extensions, not so much. The happiest grin of two weeks was when the second of the two socked in tight.
eightsandaces is offline   Reply With Quote
