In the back trunk (so cool that we have two trunks!), pull out the fuel pump relay. I cannot recall which terminals they are, but you can "jump" two of them and listen for the pump. At that same point, I guess you could also check to make sure power is being supplied to the relay.
When I set my timing, why do I flush, then pee?
