Old 02-26-2010, 11:27 AM   #4
root_werks
root_werks's Avatar
When I bought my Box I knew it had been tagged in the RF fender area. If you pull the fender liner down, you can see evidence of repair work. Done well, but you can tell if you really look.
Today I decided to really look into why my brake light wear was on all the time. Turns out the harnes on that RF wheel was bad also recently causing the ABS light to come on as well. The accident must have tugged just enough on the wires/plug that bolts onto the hub that over the years, a couple of the wires finally worked appart.
Harness from wrecking yard fixed both issues.
Cool!
root_werks is offline   Reply With Quote
