Old 02-25-2010, 08:01 AM   #10
dallison
dallison's Avatar
i replace the fluids, belt, pads and any other normal wear items regularly. Things like a water pump, alternator, etc i won't touch until they fail. Sometimes they can last the life of the car and sometimes not.
Normally 2x a year i will remove all tires and inspect the car. Usually in the spring and then in the fall.
The one thing that i have done as preventive maint was the aos. It is still in the box but i'll be changing it. I have seen the stories and it wasn't that much so i'll change it.
dallison is offline   Reply With Quote
