Old 02-24-2010, 06:36 PM   #7
cliptfc
hey, hang on a second. I had the same problem, changed out the ignition switch, and still had the problem! It turned out my lock assembly just needed oiling! I think your ignition lock assembly is stuck in, pushing the button on the ignition switch!
There is probably a better way to fix this, but I hit the lock assembly with a shot of brake cleaner, let it air out, then hit it with a shot of WD40. Worked great after that...
cliptfc is offline   Reply With Quote
