Old 02-23-2010, 09:26 PM   #3
Lil bastard
Lil bastard's Avatar
Originally Posted by embryoguy@mac.com
can i ask how much approx for it? and how easy or should i have my mechanic do it?
thanks very much for info.
do you have a link for it?
nevermind ! i got the info.! thanks very much.
The ignition switch, or more properly, the starter switch is under $20.
To swap it, you remove the D-side side air vent supply tube, then worjking under the dash, pull off the electrical connector to the switch and remove the two screws holding the ignition switch to the mechanical ignition lock - you'll need a narrow screwdriver such as a jeweler's or eyeglass repair screwdriver. Pull off the old switch, push on the new switch, retighten the scews and replace electrical connector and air vent supply. That's it. Should take less than 15 min. with a difficulty rating of 2:10.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
