With my luck, I'd chew up an IMS bearing about the same time I hit tipple digits with the RMS collapsing because the AOS couldn't take anymore causing the engine to lock hard before I could push in on the clutch that now failed locked sending the Box into a terrible spin throwing it into something much more solid than itself causing just enough damage to not total it just as an officer of the law happened to be passing by and as luck would also have it, witness the entire event to help in my proper recollection for the judge.
Or something like that.
