That's pretty good, TP Jr. Where do I sent the $1?
http://www.renntech.org/forums/index.php?showtopic=1562
I like the plastic fork which is an old BMW trick.
The real trick is to put the needles back on the shafts where they were before since they are not "keyed" or your gauges will be off. We also put tape around the middle dial because some people complain about light bleeding through with aftermarket faces.
We do test the cluster before it is put back together.
