Old 02-12-2010, 07:30 AM   #12
JFP in PA
Originally Posted by Jake Raby
a 5/16" (or 8mm) steel dowel inserted through the crank pulley and into the crankcase locking boss does the trick just fine.
I am putting together a kit that includes this improvised tool for the job.
Jake, a quick question: Are you cutting away the boss used to hold the OEM pulley; and if so, how do you hold the new one or lock the engine position for service once the original boss is cut away?
