Old 02-09-2010, 07:28 PM   #10
2K3_Boxster_S
Originally Posted by Burg Boxster
It depends.... what does the sticker on your amp say?
If 4x40 - the brown plug should be connected to the back of your head unit
If 6x40 - the wires coming from the female side of your brown plug should go to the amp.
No sound to the rear speakers would have to do w/:
- the disconnected wires for the brown plug (if 6x40 amp)
or
- the brown plug not being connected to back of h/u (if 4x40 amp)
If 6x40 amp, we need to know which part # to correctly assign the pins. If from a 996 (the first three digits of p/n will be 996) then they should be inserted into pin locations 5, 15, 6, 16 on the plug (use a magnifying glass to see them molded into plug). If it's from a 986, it's 4 different pin #s.
I'll check out the amp tommorow and find. I think these have to go to this amp in the frunk. The wiring is factory, it hasn't been tampered with.
Thanks for the help
2003 Boxster S
2K3_Boxster_S is offline   Reply With Quote
