Thread: Litronics no go
Old 02-09-2010, 03:36 PM   #5
litteng
litteng's Avatar
bulbs
i just pulled a set (on my passat) where i was having problems on startup, one or the other might not fire. turned out to be a low voltage problem which was easily remedied, so check the voltage to the ballast, then try direct to battery connection to bypass all the car electrical system.
i had a bulb burn out recently too. and the only way to confirm a bulb or ballast is to swap with know good parts either side to side or with a buddies car using the same type bulb.
if these are the factory litronics its probably a D2S bulb which is common to number of OEM HID systems, you may have the same bulb in another vehicle
claus
03-r1100s, 11-f800st, 09-987.2, Norton Commando
auf adlers fluegeln getragen
litteng is offline   Reply With Quote
